60 Park brake light switch - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    Park brake alarm switch
    Pat's park brake switch shown is what I have. The wires are as per my diagram as well. Does it use a seperate flasher for the light?
    • Larry P.
      • June 30, 1999
      • 481
      • Dennis A.
        • April 30, 1999
        • 1010
        #18
        Re: Park brake alarm switch
        On '61 & "62 cars, the brown wire went directly from the parking brake lever switch to the "flashing" Bulb # 357. I believe earlier cars wired to a tung-sol flasher unit that was mounted above the kick panel, then to the bulb. The brown wire starts from the fuse box.
        • Dennis A.
          • April 30, 1999
          • 1010
          #19
          • Joe Rosenti
            #20
            A comment/question on this post. The 1960 and 1961 Owner manuals indicate a #90 bulb for the parking brake alarm. The 1960 AIM calls for part #131282 bulb (#53 according to my 1961 Chev. parts book). The 1961 AIM does not indicate a bulb (that I can find) and does not indicate FOA 107 Park Brake Alarm option.
            I did find part 9412348 #257 w/flasher and part 142453 #90 bulb, (also for park brake alarm) in the 1961 parts book. What is the correct bulb for a 61???
            • Joe Rosenti
              #21
              • Ted S.
                • January 1, 1998
                • 747
                #22
                Re: Mine looks a little different...
                Pat, on my '58 the flasher is attached to the top of the drivers side kick panel via a small metal clip. It looks like someone used a wire tie to attach yours to the harness. I believe it was the same for both years. Other than that it looks correct.
                Larry, the light goes into a hole in the back on the drivers side of the speedo. It's opposite the high beam indicator. There's an indicator that says brake.
                Hope this helps.
                • Ted S.
                  • January 1, 1998
                  • 747
                  #23
                  Hope this helps.
                  • Dennis A.
                    • April 30, 1999
                    • 1010
                    #24
                    Joe...
                    Sorry about a typo, the flasher bulb is a #257(#9412348). #57 was for '58 - '59 cars
                    • Dennis A.
                      • April 30, 1999
                      • 1010
                      #25
                      Joe...
                      • Joe Rosenti
                        #26
                        Dennis,
                        Thanks for the reply. I did not know what the correct bulb is, and was confused because the #90 bulb is listed in the 1961 owners manual, but does not flash.
                        • Joe Rosenti
                          #27
                          Dennis,
