Gas pedal-59 - NCRS Discussion Boards
Gas pedal-59
  • Paul Robinson
    Gas pedal-59
    I cannot keep my pedal from popping off the little ball retainer. Any suggestions?
  • Ed Jennings
    Re: Gas pedal-59
    You mention retainer, there should be two of them. Often the original studs are rusted and worn. The replacements are pretty cheap. I have had the same problem on a couple of C1's that was eventually solved with a call to Corvette Central (or whoever your favorite supplier is).
    • Ed Jennings
      Re: Gas pedal-59
      • terry leeker
        Re: Gas pedal-59
        I also have this problem. I have the new studs and gas pedal from C.C. The rubber pedal has two molded in holes that the ball studs fit in. Are there also "retainers"
        • terry leeker
          Re: Gas pedal-59
          • Jim Mitchell
            Re: Gas pedal-59
            Terry,
            The gas pedal snaps down over the studs.
            • Jim Mitchell
              Re: Gas pedal-59
              Terry,
