60 Wiper motor alignment - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    I know the motor is supposed to be in home position. If I align the pully with the way the cables are supposed to go on, looking at it from the front of the car, the pin on the bracket is between 7 & 8 o'clock with the other side at between 1 and 2. Not close to where the motor stops. Is home when each end points to the raised bumps in the mounting bracket on the motor? If not where is it?
    Larry
  • Larry P.
    • June 30, 1999
    • 481
    And the answer is.....
    Yes, When the motor stops in home position the drive is aligned with the little raised bumps on the mounting bracket and the cables go on.
    • Larry P.
      • June 30, 1999
      • 481
