C1: Gauge hookup - NCRS Discussion Boards
C1: Gauge hookup
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12775
    C1: Gauge hookup
    Hi all,
    Just a little more help needed to be sure everything works out fine:
    How are the gauges for the fuel and temperature hooked up (in a 59-er) ? Pink left (driver side) or right (passenger side) ?
    thanks for your help,
    Rob.
    the 1959 restauration project
    Rob.
    NCRS Software Developer
  • Ed Jennings
    Re: C1: Gauge hookup
    If memory serves, both pink (power)wires go on the outboard side. The wiring diagram shows the proper installation. The only thing wrong on the ST12 diagram is the reversal of the ammeter connections. One of your terminals on the fuel gauge should have a warning tag cautioning you not to hook power to the sender terminal.
    • Ed Jennings
