fan clutch ID - NCRS Discussion Boards
fan clutch ID
  • Chris H.
    • April 30, 1990
    • 817
    fan clutch ID
    This fan clutch came on my 62. I have since replaced with an original.
    Can someone tell me what this came off of or what it fits? Need to get rid of it.
    Thanks, Chris
    fan clutch pictures
    Can't See Pics - Requires User Login/Password *NM*
      • Chris H.
        • April 30, 1990
        • 817
        Re: Can't See Pics - Requires User Login/Password
        Sorry again. Some times it works fine.
        Let me explain it. It looks on the engine side like my correct 62 with aluminum curved cooling fins. On the front side the metal skin is flat except for a raised center (~ .5" diameter) and 6 raised ribs around the center but at a slight angle. Make any sense?
        thanks, Chris
        • Chris H.
          • April 30, 1990
          • 817
          thanks, Chris
          • Chris H.
            • April 30, 1990
            • 817
            Lets try this one
            http://www.snapfish.com/slideshow/Al...06/t_=19939099
            • Chris H.
              • April 30, 1990
              • 817
              Lets try this one
                • 43221
                Chris-----
                I still can't see the pictures. However, what you describe sounds like an aftermarket-type clutch. Does the mounting flange have 4 holes or 4 slots for mounting?
                  • 43221
                  Chris-----
                  • Chris H.
                    • April 30, 1990
                    • 817
                    Lucia-fan clutch
                    Sorry I cannot get the pictures to work.
                    The attachments are open slots.
                    • Chris H.
                      • April 30, 1990
                      • 817
                      Lucia-fan clutch
                        • 43221
                        Re: Lucia-fan clutch
                        Chris------
                        In almost all cases, the slots instead of holes indicate an aftermarket-type unit. All original GM fan clutches that I am familiar with that were used in the 60-82 period had holes on the hub for attachment and not slots.
                        The slots are designed for a "one-size-fits-all" approach to fan clutches. The slots make them work with both the small and large flange patterns. GM fan clutches were specific for either pattern (and, other things, too).
                          • 43221
                          Chris------
                          • Chris H.
                            • April 30, 1990
                            • 817
                            Thanks, Joe. I will throw it on Ebay and see if anybody needs it.
                            Chris
                            • Chris H.
                              • April 30, 1990
                              • 817
                              Chris
