Rear end ratios...why the difference? - NCRS Discussion Boards
  • Warren F.
    • December 1, 1987
    • 1516
    Can someone explain why Chevrolet had similar ratios, some the same and others so close to each other?
    For example: Corvette 3:08 Camaro 3:07
    3:36 3:31
    3:55 3:55
    3:70 3:73
    4:11 4:10
    4:56 4:56
    • 15692
    Re: Rear end ratios...why the difference?
    Different gear tooth counts depending on the axle design. For example, the 4.10 ring and pinion on the Camaro axle is 41:10. The 4.11 Corvette ring and pinion set is 37:9.
    As a general rule for similarly sized gear pitch diameters, the larger the tooth count, the higher the torque capacity because the load is spread out over more tooth contact area.
      • 15692
      • Warren F.
        • December 1, 1987
        • 1516
        Thanks for the explanation, Duke.
        Could you give me another example using the Corvette 3:70 vs Camaro 3:73?
        • Warren F.
          • December 1, 1987
          • 1516
            • 15692
            The Corvette 3.70 is 37:10. Off hand I don't know the count for the Camaro 3.73, but 11 x 3.73 = 41.03, so it's probably 41:11.
            Drive pinions typically have 9 to 14 teeth. A 10 tooth drive pinion will always yield a zero in the hundreths place. Those are easy. To guess the tooth count for other ratios, multiply the ratio by different drive pinion tooth counts until you come up with a ring gear count that is within .05 of being an integer.
              • 15692
