headlights - NCRS Discussion Boards
headlights
  • lyndon Sharpton
    headlights
    My headlights wont come up with the switch. Only come up when I pull the override,is my switch bad? they trun on just will not come up, sometimes they go down with the switch.
  • Ed Jennings
    Re: headlights
    Check the vacuum line to the switch for cracks/leaks.
    • Ed Jennings
      Re: headlights
      • lyndon Sharpton
        Re: headlights
        where under the dash is the switch located? is it on the fire wall close to the fuse box?
        • lyndon Sharpton
          Re: headlights
          • Michael W.
            • April 1, 1997
            • 4290
            Re: headlights
            It's attached to the headlight knob, behind the dash.
            • Michael W.
              • April 1, 1997
              • 4290
              Re: headlights
              • Dennis A.
                • April 30, 1999
                • 1010
                Re: headlights
                Lyndon...
                there are ton's of article on the Headlight vacuum system. Most of the system is in the engine dept., running up to the two canisters in front of the radiator. (C3's)
                • Dennis A.
                  • April 30, 1999
                  • 1010
                  Re: headlights
                  Lyndon...
                  • lyndon Sharpton
                    Re: headlights
                    does the headlight on an off switch have the headlight vacuum door open switch on it?
                    • lyndon Sharpton
                      Re: headlights
                      • Michael W.
                        • April 1, 1997
                        • 4290
                        Re: headlights
                        Yes.
                        • Michael W.
                          • April 1, 1997
                          • 4290
                          Re: headlights
                          Yes.
                          • Jim T.
                            • March 1, 1993
                            • 5351
                            Re: headlights
                            The Winter 2005 Corvette Restorer has an article on rebuilding the 68-77 Corvette light switch. It mentions that if the vacuum function has failed to replace the switch. wwwjoerayparts.com has the Delco #1995191 Corvette light switch listed. Some of the other Corvette venders sell reproduction switches.
                            • Jim T.
                              • March 1, 1993
                              • 5351
                              Re: headlights
