1966 Chevrolet Corvette Grand Sport on Ebay - NCRS Discussion Boards
  • Erik S.
    • January 1, 2005
    • 407
    This is offered on the German ebay site - over USD 140,000; does this look like the real deal to anyone?
    Erik
  • George C.
    • December 1, 1988
    • 583
    Re: 1966 Chevrolet Corvette Grand Sport on Ebay
    Hi Erik, The only real one's were the 5 "1963" Grand Sports built by Chevrolet.This is a copy,restoration of a 1966 to look like the original Grand Sport.Very nice job though. Hope it's scaring alot of foreign cars on the autobaun. Save the Wave.>George
    • Bob R.
      • June 30, 2002
      • 1595
      I have to brush up on my German to read the description.
      • Robert E.
        • April 1, 2004
        • 398
        babelfish German to English Translation
        Absolutely singular Frame off restoration World-wide one the most spectacular Corvetten at all + + + complete new running engine for over 36,000, - EUR + + + Sensational engine performance of over 643 HP ------------------------------------------------------------------------------- DESCRIPTION ------------------------------------------------------------------------------- In the 60's. Years developed general of engine for the fight of the giants, the Corvette Grand sport Coupe. In December 1963 in Nassau on the Bahamas, for the first time the Corvette Grand sport Coupe was used, with the Nassau speed Week and pustete the Cobra impressive from the runway around the aerodynamics of the Grand sport Coupe to improve again clearly, 1964 the Chevrolet Corvette Grand sport roadster in to live called the racing department of general of engine built the Grand sport Coupe to the roadster around it only two vehicles for the running employment was built ------------------------------------------------------------------------------- A LEGEND WAS AROUSED AGAIN TO THE LIFE Inspired of the history of the Grand sport, the legendary Chevrolet Corvette Grand sport roadster again to the life arouses the base vehicle is an original Corvette Stingray Coupe of 1966 the singular one and most complex restoration and modification began in February 2001 and ended in July 2003 the 66.er Corvette Coupe completely one divided and with most complex means, restored and the Grand sport roadster converted in a specialty firm became in over 900 working hours, which does not transform Coupe, exactly the same, as into the 60.er years of general of engine, into a roadster it many vehicles to give, one such perfection in things of gap dimensions and surface treatment exhibits after that the most complex treatment of the body locked was, the body was painted and then you to find over-painted screws or frame parts for this project, a completely new running engine does not complete, with an engine performance of over 643 HP built it an engine was built, which can be driven with normal fuel (no running fuel) and perfect an everyday life fitness to offer a completely new Bow Tie running block has is taken, in the USA in Dragster or speedboats blocked and with several thousand HP to be driven can the engine gets from 8,8 litres capacity an achievement of over 643 HP and with a single butterfly valve fuel injection system of the company Viktor&Guenther equips the torque kindles breath-robbing 880Nm is switched with a completely overhauled as basis 4-Gang T-10 transmission the particularly manufactured racing chassis is in the height, as well as pressure and traction phase adjustably around the roadster perfectly to Beher, a rack power steering blocked contrary to other running vehicles of this epoch, can the roadster very easily and before all direct be steered the interior equipment much complex from an upholsterer in leathers manufactured ultralight aluminum Kirkey of running seats to originate from the American dragees Race series all parts such as framework, joints, sockets, or electrical connection completely or were specialmanufactured renewed for the vehicle the Sidepipes and the fan elbow unions were restored specially in high-grade steel ------------------------------------------------------------------------------- ENGINE SPECIFICATIONS Chevrolet Corvette Grand sport roadster Engine mount: CNC of milled Bow Tie Racing block on 540 cubic inch (8.8 litres) bored crankshaft: Skat Crank 4340 steel fine-heaved piston rods: Skat h-Beam 4340 steel piston: FOR EACH Pistons with speed pro piston rings Brodix BB2 Xtra CNC ported cylinder head Crane scooter Camshaft cam shaft Crane gold Race Rockers rocker arm with Crane Stud Girdles nockenwellenantrieb of Pete Jackson Gear drives aluminum flywheel of Hays with running clutch fine-heaved with crank gear shock-mount: Fluid absorber Moroso Racing oil pump Hamburgers Circle TRACK oil pan MSD ignition system with trigger acceptance on the crankshaft suction tube injection with single butterfly valves 52mm von Viktor Guenther GmbH with K&N air cleaner and two high speed gasoline pumps Edelstahlsidepipes specialmanufactured by Bosch RCI safety running tank from plastic with tank foam in aluminum containers high speed water and oil cooler with Cosworth electrical exhaust rack power steering of the company Steeroids with university ball joints at the tie rods as the guidance joints of Flaming River CNC Billet Steel original Kirkey aluminum pro Street dragee Seat with RCI 5 point belts + high-grade steel elbow unions + high-grade steel mufflers all gasoline and oil lines with Earl screw connection ------------------------------------------------------------------------------- If you have still questions to the vehicle, we are to you each time gladly at the disposal Inzahlungnahme of all makes possible Sports car + old timers + Exoten + roadster + Limosinen + small cars For further questions, we are to you each time gladly at the disposal -------------------------------------------------------------------------------
        • Mike Cobine
          My amazement is
          how often those who are selling the Grand Sport conversions call into the description enough Grand Sport history to make you think this is somehow one of the five built. They use a lot of smoke and mirrors before you find simply that this is a "XXX Custom Grand Sport kit" or a "handmade Grand Sport" or whatever.
          I know and was involved with the guy who made possibly the first, one that I think Vette Magazine called "Grand Sport 006", and while it was a neat car, it was still just a customized Corvette.
          And he was rightfully proud of it.
          But these sellers seem to be ashame to admit they built it or that they bought a kit, instead using 50 lines of text to mask it behind Grand Sport history.
          • Mike Cobine
            My amazement is
              No, it's not, and this is about the tenth time it's been listed on eBay in the last year; the guy called me about six months ago and offered it to me since he knew I was a GS freak and had built one, and I politely declined. It's a beautiful piece of craftsmanship, but many important areas where it should be faithful to the originals were ignored when they built the car; now it's just another "kit car". You'd think if someone was going to pour a major bundle of money into the build a GS replica, they'd at least put it on a tube frame
