1964 Trim Numbers - NCRS Discussion Boards
1964 Trim Numbers
  • Jerry DiTullio
    1964 Trim Numbers
    Can somone with midyear experience translate this trim tag for me? I loaned out my manual.
    B06
    837 | A-051
    491C | 940A
    VIN 40837 S 11565
  • Rick A.
    • July 31, 2002
    • 2147
    Re: 1964 Trim Numbers
    Since no one responded - let me take a shot
    B06 October 6, 1963 build date
    837 Corvette Sport Coupe | A-051 AO Smith Body #051
    491C Black Vinyl Interior | 940A Satin Silver Exterior
    VIN 40837 1964 Coupe S St Louis 11565 VIN number
    FYI - are you sure you aren't missing one number from the VIN??????? reason I ask, for instance mine is 30837S119367
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • Wayne W.
      • April 30, 1982
      • 3605
      And a 11000 serial number would be much later than that.
      • Andy F.
        • January 1, 2004
        • 93
        B06 is your build date, I'm not sure what month 1964 model production began, but probably a Fall 1963 (October 6th maybe)car. Someone else can probably help you there. 837 is the body style 837 = Coupe. A-051 is the body number...A means the car was an AO Smith body versus a St Louis build. 491C is a two-tone interior Silver vinyl with Gray trim. 940A is Satin Silver.
        How'd I do?
        Andy
        • Andy F.
          • January 1, 2004
          • 93
          Oops I deciphered the trim code wrong...it should be two-toned white with black.
          • Rick A.
            • July 31, 2002
            • 2147
            Wayne,
            of course, you are correct - but it just looked weird the way it was listed, and that is why I asked if something was missing
            Rick Aleshire
            • Tom D.
              • September 30, 1981
              • 2132
              Was it #565 then? Or... *NM*
              https://MichiganNCRS.org
              Michigan Chapter
              Tom Dingman
              • Bob R.
                • June 30, 2002
                • 1595
                Re: Was it #565 then? Or...
                Could the B06 be for Feb 6. The 11565 Vin would be a Feb build date.
                • Mark G.
                  • March 1, 2001
                  • 227
                  • Scott Butville
                    All '64's should have 6 digits after the "S", the first of which is always a "1". The "A" body number code stands for A.O. Smith. They did not start to build bodies until Jan '64. On their bodies "B" is February while "B" is October for St. Louis bodies. The digits after the "S" should be 111565.
