How to best remove Headlight Bearings - NCRS Discussion Boards
  • Scott Marzahl
    Is there a best practice to remove those large ball bearings on the headlight shafts. They all seem to be frozen on there pretty good.
    BTW, are the headlight buckets on a '67 aluminum or pot metal?
    Thanks.
  • Gordon Peterson #4961
    Re: How to best remove Headlight Bearings
    Soak them in penetrating oil for a loooong time. Try to get them to turn first then pull on 'em. They are hollow, and they'll dent or distort. So don't pry directly against them with any tools. Be patient. Good luck.
    Pete
    • Wayne W.
      • April 30, 1982
      • 3605
      You are not likely to get them off in one piece anyway, so just cut them off. This will leave the brass sleeve of a bearing still on the shaft. split the sleeve to relieve it from the shaft. Replace with the new plastic bearings.
      • Gerard F.
        • June 30, 2004
        • 3806
        Headlight buckets are pot metal castings
        So, the Technical Guide says
        Jerry Fuccillo
