date an points - NCRS Discussion Boards
date an points
  • lyndon Sharpton
    date an points
    if the date is way befor are after the build date on a carb would you just lose the five points, all though the carb # is right?
    Re: date an points
    Carburetors normally are allocated 40 originality points, so you'd lose 20% of that (8 points) for an incorrect date, assuming the other four axes are correct (finish, installation, completeness, and configuration), and you'd still be eligible for all the condition points.
      • 15606
      Re: date an points
      John,
      No offense or flame intended here.
      In some classes the carburetor date (and some other component dates) are called out on a separate line. The date may have more, or less, than 20% of the total item points in those cases, although it is usually around 20%.
      Without a current copy of the applicable score sheet these point suggestions are just that, a suggestion.
      Current score sheets are available to members in PDF format from the National Judging chairman by means of an email request to him. See the contacts button at the top of the page.
      • Rick S.
        • January 1, 2003
        • 1203
        Re: date an points
        John, I have a service replacement carb, would the same deduct apply as an incorrect date?
        Rick
        • Robert C.
          • December 1, 1993
          • 1153
          Re: date an points
          If the service replacement has the correct part#, list# etc.it would be all ok except the date. The same deduction would apply.
          • Rick S.
            • January 1, 2003
            • 1203
            Re: date an points
            Thanks Bob
              Re: date an points
              Yup, I agree - I should have said "generally" instead of "normally"; I was referring to the '67 sheets as an example, as I don't have '69 sheets. I suggested to Lyndon that he get a set of score sheets from Roy in another post up near the top of the board.
