date - NCRS Discussion Boards
date
  • lyndon Sharpton
    date
    OK for all you code busters what is this break down to? 0251 on a carb 7041205 I have a old judging manual. so if I am reading that right it is a late 71 carb?
  • Charlie P.
    • July 31, 2003
    • 260
    Re: date
    Should be 251st day of 1970; early September. Early '71 carb.
    • lyndon Sharpton
      Re: date
      thanks Charlie
      • lyndon Sharpton
        Re: date
        I am reading that as January 001-031 (025) 1 for 1971. I am confussed. would that be right the carb is 0251
        • lyndon Sharpton
          Re: date
          No you were right I was reading that wrong, it is a 70 carb with a september date
            • 15601
            Re: date
            Lyndon,
            It is a carburetor for a 1971 MY vehicle. The 4th number indicates the model year it is applicable to.
            7041205 = 1971 365 HP, LS5, 4-speed.
            0251
            The first three numbers are the Julian day of the year 025 = January 25
            The last number is the year -- in this case, 1971
            BTW: ALL the above information except the first paragraph is in the 1970-71 TIM&JG, plus a whole lot more. Go for it. I cheated and looked it up.
            • Brandon Metzger
              Re: date
              I don't realy have any input on this but a question on my own carb. I have a '72 Jan. built LS5 M40. I obtained a carburator with the following numbers. I believe it is for a '72 with the date I am looking for but I would like to double check before I spend the money to get it rebuilt.
              Numbers are 7042220 J1 EM
              I is a Quadrejet manufactured by Carter.
              Thanks for the input.
              Brandon
                Cheat, like Terry did.....
                and look the info up in the Judging Guide! You'll find it documents a difference between the date coding sequence for Rochester produced QJets and those from Carter. While Rochester units use an all numeric Julian dating system, Carter units use an alphameric system....
                The 'J1' decodes to September, 1971. The JG book will also tell you Judges expect to see a 7042216 QJet atop the intake of a '72 LS5, automatic, Corvette. Therefore, while the carb might be dated 'right' why put a lot of effort into getting a carb core that's not original to your engine rebuilt unless your intention is to simply drive the car....
                • Charlie P.
                  • July 31, 2003
                  • 260
                  Re: date
                  I messed that one up. I got it bass ackwards. My July 12 car has a carb date of 1661- June 15, 1971.
