C2 Removal / Repro of front harness straps - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    Removing front wiring harness from the left inner fenders of a 1967. The black plastic attaching straps don't look like they will be salvageable, if I do figure out how to remove them. Any thoughts on removal, other than just pulling on them?
    Also, I assume there are reproductions of these holder loops, but are they any good (accurate repros)? I can supply a photo if needed.
    Thanks in advance.
    Tom Dingman
    P.S. Note that www.MichiganNCRS.org can now be reached via www.MichiganNCRS.com also. Both are "forwarding addresses".
    Michigan Chapter Site Link
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Scott Marzahl
    Check out the Doc's catalog
    He carries them, I ordered a set and they look fine to me, but what do I know, I'm just a rookie
    • Tom D.
      • 2134
      Re: Check out the Doc's catalog
      Thanks Scott - Don't feel bad about rookie status. I've noted the Steelers have a pretty good one.
      Michigan Chapter
      Tom Dingman
      • Rick S.
        • January 1, 2003
        • 1203
        Tom,
        I talked to a fellow at the Windsor National and he had super glued them together because you can't seperate them once they are assembled. His super glue was coming apart so he was trying to use electrical tape in a pinch. He stated the judges could tell the difference between the original and repo but what do I know, I'm only a sophomore in this class. Oh, he had cut his original ones to put in a new wiring harness.
        Rick
          • 11644
          Yep, the Doc's are quite good. Far better than trying to salvage a brittle original or super gluing together.
          Patrick
