186 heads - NCRS Discussion Boards
186 heads
  • GL Anderson
    186 heads
    I have a set of 1970 LT1 or z-28 186 heads. They have 2.02 intake valves and 1.60 exhaust valves. I know they also came with 1.94 and 1.50 valves. How do I tell if these were original 2.02 heads or if somebody added them? Thanks in advance for your help. GL
    • 15674
    Re: 186 heads
    Original 2.02/1.60" heads have radiused combustion chambers. It's about a 2.34" circular cut centered on the inlet valve to unshroud it. The 1.94/1/50" versions did not have this machining operation.
    Of course, if the valve size was increased and the proper radiusing was done, it would be tough to tell.
    Installing the larger valves without unshrouding the valve with this cut will actually reduce flow, but I think it was common to increase valve size and not unshroud the valve.
    • GL Anderson
      Re: 186 heads
      Thanks Duke I will get them out and see what they look like. I would suppose that 2.34 cut could be duplicated if necessary. Thanks again GL
        Re: 186 heads
        The factory unshrouding cut with 2.02 valves looked like this; most machine-shop conversions don't have it.
        • GL Anderson
          Re: 186 heads
          Thanks John that helps!
            • 15674
            Re: 186 heads
            A machine shop should be able to make the unshrouding cut if you increase valve size. Also the sides of the chamber should be hand blended out to the edge of the bore to eliminate any overhang.
            I don't recommend increasing valve sizes if the 1.94/1.50" valves are installed. The major improvements in cylinder head flow are pocket porting, port matching, and a careful three angle valve seat with top 30 deg. cut on the inlet valve to eliminate excess overhang (leave ,010" overhang on each side with .040" inlet and .060" exhaust seat widths). Do this and the slight increase in valve size is not worth the loss of reliability IMO.
            Enlarging the valves increases the propensity for a crack to develop between the seats. Of course, if your heads already have the larger valves go ahead and continue with this size. You can't go "back" once the seats are opening to the larger size.
            • GL Anderson
              Re: 186 heads
              Hey Duke: They already have the 2.02 intake valves in them. Looking at the pic, the heads I have don't have the factory cut for the bigger valves. I have talked to the machine shop about cutting them as shown. The heads already have a nice pocket porting job done on them to smooth out all the rough casting edges. I will have the 3 angle valve job done on them as you suggested. I also have some Cosvega stuff to talk to you about but will do that off board. Thanks GL
              • Mark G.
                • March 1, 2001
                • 227
                • GL Anderson
                  Re: 186 heads
                  Re the aluminum heads I have, GIF is cast into the heads with a casting number of 3772895. Casting date 6-24-59. They don't have any valve seat inserts. No Bowtie logo. There are several number/letter combos stamped into the ends of the heads purpose unknown to me. Also under some of the chambers there are small single numbers stamped into the head surface, purpose also unknown. Unlike the other known NOS set mine haven't been ported to death. If you want to know what I mean by that look up ebay item 4517841288 that is on right now.
                  • GL Anderson
                    Re: 186 heads
                    Mark here is a pic of the combustion chamber of the aluminum head showing there are no valve seat inserts. Sorry for the quality but I need a better camera. GL
                    • Mark G.
                      • March 1, 2001
                      • 227
                        • 43221
                        Re: 186 heads
                        Mark and GL-----
                        I was unaware that these small block aluminum heads did not have valve seat inserts. It's hard to imagine that the durability of these heads would have been very great. I don't think that there are any other PRODUCTION, SERVICE or aftermarket aluminum heads that don't have inserts on both the intake and exhaust, and most of these heads are modern alloys and heat treated, too. Not all aluminum heads have HARDENED or special material valve seat inserts, though. Many were just cast iron.
                        • GL Anderson
                          Re: 186 heads
                          I rather think these aluminum heads were the nearly if not exactly the same as the iron 461X heads. They are fitted with 1.94 intake valves rather than the 1.72 intakes in the heads of the day and the same 1.50 exhaust. The heads on ebay have been ported from the stock configuration. Here is a pic of the stock intake ports. With the exception of the screw in studs I am not to sure the factory did a lot of machining that would be different than what was done to the iron heads. Wasn't there so don't know for sure but it doesn't look like it to me. GL
