Midyear Power Steering Cylinder rebuild - NCRS Discussion Boards
  • Gary C.
    • March 1, 1998
    • 236
    Two questions re the power steering cylinder on my 63.
    I cannot remove the ball stud from the relay rod. Tried some moderate wacks on the stud, but did not want to risk bending the rod. Also tried to rig up something using my balancer puller to push the stud out but that was not successful either. Anyone have any helpful hints?
    Also, anyone have any suggestions for removing the cylinder shaft seal?
    Gary
  • Dick W.
    • 10483
    Re: Midyear Power Steering Cylinder rebuild
    Gary,most tool jobbers and stores sell a tie rod end removing tool. Looks like a tuning fork. Some parts stores rent such tools.
    Dick Whittington
    • Gary C.
      • March 1, 1998
      • 236
      Thanks for the response. I have some tie rod and ball joint seperator tools and may yet try one here, but I was trying to get it off with the original rubber boot intact. I do not see any way to use the "pickle fork" tool without sacrificing the rubber boot.
      • Dick W.
        • 10483
        You MIGHT be able to remove it by using a thick nut screwed on the threads leaving the stud threads down in the nut a turn or two. Take a two jaw puller with a flat tip on it. Clamp the puller on the relay rod. Tighten the puller as much as possible. Take a hammer, preferrably at least a two pound, and hit the top of the screw on the puller HARD. This should pop it loose. Sometimes you can hit the side of the socket in the relay rod had and it will pop. If this does not work I guess you will have to resort to the separator. DO NOT USE HEAT! The rod is heat treated and you can and will weaken it if you attempt to use heat to remove the cylinder.
        If you do damage the boot I belive that you will find an assortment on the HELP! rack at most parts stores.
        Dick Whittington
        • Eugene B.
          • May 31, 1988
          • 710
          Gary,
          The hammer blow that seems to work is one that is delivered to the side of the relay rod, perpendicular to the stud.
          Back up the relay rod with a second hammer or place it on an anvil, and strike the opposite side of the relay rod with a good hammer blow. The blow creates sufficient vibration to separate the stud from the rod.
          Sorry, but I can't help with the cylinder shaft seal. When my power cylinder was rebuilt, they had to cut it at the mounting end, replace the rod and internal parts, and reweld the body. If the polished rod has a wear mark around it (in the spot where the wheels are straight ahead), it will probably have to be replaced.
          Good luck on your '63.
          Gene
