C3 SB oil preasure sender - NCRS Discussion Boards
  • Jim Callan
    Can the plastic line be removed/replaced WITHOUT removing the sending unit ??
    I removed the small 'cap/nut' put the line doesn't seem to want to come out.
  • Dick W.
    • 10483
    Re: C3 SB oil preasure sender
    It can be removed with some gentle persuasion, or maybe not so gentle persuasion. I would plane on replacing the line as it is probably brittle.
    Dick Whittington
      • 43221
      Jim-----
      There is NO sending unit for oil pressure on C3 Corvettes which are equipped with a pressure line. The piece that you are probably referring to is simply a fitting and, as Dick mentioned, you don't need to remove it to remove the line. You do, of course, need to remove the tubing nut from the fitting.
      Oil pressure sending units for C3 Corvettes did not begin until the 1974 model year. Then, a wire connected the the sending unit to the gauge and no pressure line was used.
