Heat riser, Is this open or closed - NCRS Discussion Boards
  • jim #42767
    The heat riser is frozen, is it stuck open or closed?
    • 43234
    Re: Heat riser, Is this open or closed
    Jim-----
    It's currently in the "open" position.
    • Dale S.
      • November 12, 2007
      • 1224
      There is a penetrating oil(actually spray) named "Maltby Premium Rust Dissolving Penetrant", that we sold in our parts store for years. It works better than "P.B.Blaster","K&W knocker loose", "Wd 40" It has something they call "R-90" and it really works. If you can still find it you will be happy with it. Anyone else know about this? It was made in Calif. I heard they moved to Nevada be cause of Ca. state laws. The can I have says" Maltby International Chemical. Sun Valley, Calif. 91352. and the part number is 616-15A hope this helps. Dale
      • Chuck L.
        • July 31, 1996
        • 260
        There's a Maltby International Chemical located in Carlsbad, CA that shows up if you do a Google search with their address and phone #.
        Chuck Lyman
        Kansas City Chapter
        • Verle R.
          • March 1, 1989
          • 1163
          Maltby web site:
          Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
          • Stephen W.
            • March 1, 2002
            • 301
            you might try GM Heat valve penetrent. I use the stuff for everything and it really works. I've had a can for a long time but I think your dealer should still carry it.
