C1 Tach Rebuild - NCRS Discussion Boards
C1 Tach Rebuild
  • Michael K.
    • August 31, 2004
    • 170
    C1 Tach Rebuild
    The tach cable in my 57 has broken many times throughout the years. It was removed by the previous owner a couple of years ago and never replaced. I installed a new cable and lubricant. After starting the engine, the tach began to make a sqealing noise. I would like to have it rebuilt, but I am not sure where the best place to send it would be. I live in Michigan, and would like to take it somewhere locally. I do not have a problem shipping it somewhere in order to get the best quality rebuild. Any recommendations?
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C1 Tach Rebuild
    brian at corvette spec of maryland. they ad in driveline. good luck, mike
    • Michael K.
      • August 31, 2004
      • 170
      Re: C1 Tach Rebuild
      Thanks Mike!
      • Ed Jennings
        Re: C1 Tach Rebuild
        You can check the yellow pages for a speedometer repair shop that is a Declo authorized facility. They can probably repair it, but aren't going to do a cosmetic restoration. I'm sure they could change out a face and needle if you provided it, however.
        • Michael K.
          • August 31, 2004
          • 170
          Re: C1 Tach Rebuild
          Thanks for the advice Ed.
