C2 Dist.#1112051-0510 - NCRS Discussion Boards
  • Michael D.
    • February 1, 1978
    • 159
    Hello all,
    I came across this dist. with these #1112051 there are also other #'s 0510.....ms149 15 also there is a number 761. can anyone tell me what this dist. is from? thanks for your reply's MikeD#1787 Thanks
    • 43221
    Re: C2 Dist.#1112051-0510
    Mike-----
    The GM #1112051 distributor was originally used on 1971 and 1972 Corvettes with LS-5 engines. This is a single point type distributor.
    • Michael D.
      • February 1, 1978
      • 159
      Re: C2 Dist.#1112051/Joe L.
      Joe
      If I have this distributor rebuilt and set-up for a 65 327 will I be able to use it in my motor? Thanks again Mike D
        • 43221
        Mike-----
        Yes, you will. You might be able to use it as-is. Otherwise, you can have its advance architecture configured like that originally used for the distributor used for your particular engine.
        • Michael D.
          • February 1, 1978
          • 159
          Thanks Joe *NM*
