Cast iron exhaust donut? - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    When I took my 68 bb apart I noticed that there were only castiron donuts inside the exhaust flange, no sleeve. Is anyone familiar with this. I am assuming it is original for my car. One of mine is cracked, is there a source for them? Thanks, Terry
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Cast iron exhaust donut?
    some are made from pressed powered metal that may look like castiron
      • 43240
      Terry-----
      I've never seen a cast iron exhaust packing (donut). However, I have seen the sintered iron variety which may be what you're talking about. These are not original to your car. Primarily, these were used for truck applications but I use them for cars. Other folks do, too.
      I only recommend using these with the extensions just as used with the soft packing. The part numbers are as follows:
      2"= GM #3731062
      2-1/2"= GM #3768711
      Both of the above are still available from your GM dealer.
      • Terry F.
        • 2061
        Thanks for the responces. What I found was two castiron looking donuts and no steel sleeve inserts. I was confused because I seem to recall my assembly manual not showing anything like it. I didn't want to discard them because I met someone with another 68 that found the same thing. Thanks, Terry
          • 15606
          I believe the original seals for your car were the fiber style, with the sleeve inserts.
          • Clem Z.
            • January 1, 2006
            • 9427
            with the metal donuts they are strong enought that you do not need the sleeves. the general found a another way to save money.
            • Terry F.
              • 2061
              Thanks for the responces. I will put the sleeves back in and the fiber type donuts. Thanks, Terry
                • 11652
                I use the sleeves as well as the sintered metal donuts. I've replaced too many crappy fiber donuts in my 11 years of Corvette ownership to put up with those anymore.
                Just my $0.02
                Patrick
                • Mike McKown
                  See your FoMoCo Dealer 460 engine. *NM*
