C1 color code - NCRS Discussion Boards
C1 color code
  • chuck
    C1 color code
    I've got a 1962 c1 corvette. Its missing the color code tag, doesnt have the original engine. The title nor any of the paperwork depicts the build date. I'd like to find the build date and the original color code. Any ideas? Is there a dept within GM that can provide this information based upon a vin #?
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 color code
    C1 Corvettes had no color code tag. You can only determine the original color by doing some detective work. You can look in hidden areas and probably determine the original color unless the car has been restored well. The build date can be approximated by the VIN number, but GM has no records that will gine any detail info. The lack of trim tags on C1 cars is one of the reasons that a lot of us like to restore these cars. As long as you paint it one of the factory original colors, it will take no deducts at judging. When I do a color change on one of these cars, I strip the entire body to bare glass, and you would never be able to find any clues to it's original color, but if a car has not had such a restoration, there will be plenty of clues.
    Regards, John McGraw
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 color code
      Here is a pic. of a 61 Corvette "silver" if the Vett has never been paint striped in the truck area use a quarter to remove paint in this area to find the original color of your Corvette.
      • Roy B.
        • February 1, 1975
        • 7044
        Re: C1 color code
        Another point of interest to some is that "some" Corvettes that might be ordered with a power top option . many bodies have dimple to locate the hardware if so ordered.
        • Dave S.
          • August 31, 1992
          • 2925
          Re: C1 color code/Question for Roy
          Roy,
          I have a 61 Red car and scraped the bulkhead behind the passenger seat to hopefully see RED in crayon. I did not find it. It appears from your photo that the SILVER is on the drivers side in your photo. Am I correct. ????
          • Roy B.
            • February 1, 1975
            • 7044
            That's RIGHT! but behind the seat will tell you weather it had a hard top or soft top on most 61 ,62's. And so many other little things also that many people don't seam to know!! that I and Noland wrote about. I don't like to argue any more like many of use older NCRS guys feel today, so we just stay out of it.
            We were the ones that made this known.
              • 11643
              Dave,
              My friend's 60 has it on the trunkwall (trunk side) behind the passenger's side. A local 61 has it behind the passenger's seat back (passenger compartment side).
              Patrick
              • Gary Bishop
                Re: C1 color code
                If it was a Canadian Delivered Vette you can get most of the info from GM, Oshawa, Ontario
                • Dave S.
                  • August 31, 1992
                  • 2925
                  Patrick/Roy
                  I was under the impression that all 61's had the color behind the passenger seat. By looking at the photo and Roy responding that was incorrect. I was surprised not to find it on the passenger side when I looked. I will now scrape behind the drivers seat and I'll bet I find it. Apparently 60 in earlier cars had the color marking facing the trunk and that changed in 61.
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Because the 61 was a change over from 60, the EARLY 61 may be in the truck ( that was the pic I showed (early) later seat area. Sorry guys I for got to think of that.Getting old.
                    • Ray C.
                      • June 30, 2001
                      • 1132
                      Hi!
                      My late April 61 had silver written in green crayon behind the passenger seat.
                      Ray #36314
                      Ray Carney
                      1961 Sateen Silver 270-HP
                      1961 Fawn Beige 315-HP
                      • Dave S.
                        • August 31, 1992
                        • 2925
                        Thank guys,
                        My 61 is #4587 and as I mentioned it is not behind the passenger seat. I'll look in the trunk but my car is far from early production.
                        • Joe M.
                          • February 1, 2005
                          • 590
                          Re: C1 color code
                          Late April 61 with color "maroon" and "ST" written in green crayon dead center behind the passenger seat. Hopefully a photo attached.
                          • Joe M.
                            • February 1, 2005
                            • 590
                            Re: C1 color code
                            late April 61.....MAROON/ ST.....bulkhead behind seat
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              Re: C1 color code
                              ST marking would indicate a soft top
