Where to Buy? Original AC Delco filters? - NCRS Discussion Boards
  • Peter G.
    • December 1, 1980
    • 406
    Where does everyone buy their AC Delco filters? Air, oil, crankcase breather, pcv valve that are the closest to original and NCRS standards? I have a '73 LS4 and it has the open air cleaner housing so I think the air filter is a bit rare in it's use.
    The part numbers are:
    Oil Filter-PF25
    Air Filter-A329C
    Crankcase Breather-FB59
    Thanks.
    Peter Gregory # 4157
    National Corvette Restorers Society Since 1980
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Where to Buy? Original AC Delco filters?
    You can't buy original filters but there are repro's available at Paragon, Corvette Central etc.
    • Dave S.
      • August 31, 1992
      • 2925
      Peter,
      The 329C in NOS or used may be difficult to locate but original white non-embossed PF-25 AC filters are out there. Not sure about the FB 59 breather.
      • Dick W.
        • 10483
        I think that the NCRS Driveline would be a good starting point when looking for parts such as filters. If you do not find any listed insert a want ad for the needed filters.
        Dick Whittington
        • William C.
          • May 31, 1975
          • 6037
          There are good reproductions of the white oil filters available on ebay and also the first design blue filters with the unpainted edge rib at the top show up occasionally. The air filter will bw the most difficult to find, as Dick said.
          Bill Clupper #618
            • 11644
            There is a "repro" of the air filter available, but it's a joke. A total waste of $20. It's nothing but a current ACD filter with the "correct" words on the filter in totally the wrong font. Any judge could pick it out as incorrect.
            Going rate for a good used original one is above $300. Ouch.
            Patrick
            • Mike R.
              • May 31, 2002
              • 119
              Peter
              You can probably find an original oil fileter out there. The question is, do you realy want to put a 30 year old oil filter on your car? A bit of a risk!
              Mike
              Mike Robb
              • Peter G.
                • December 1, 1980
                • 406
                Well my car doesn't sit in a Museum and I do/or will drive her when the Spring comes so I do need clean fresh new filters that do their job efficently, but of course would like to continue putting on the most accurate parts available today at "resonable" prices.
                Peter
