'63 cookie pans adhesive - NCRS Discussion Boards
  • Steven S.
    • November 1, 1995
    • 151
    What adhesive can be used under the cookie sheets on the hood. The assembly manual says to use an 1/8" bead, but need to know brand/type of adhesive. Lacquer paint in under sheets, so adhesive needs to bond to it as well as the cookie sheets.
    Thanks in advance,
    Steve
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: '63 cookie pans adhesive
    I used 3-M rope caulk, commonly referred to as "dum dum". Put "X"'s under each sheet and screwed/bolted them in. Chuck
