C 1 between seat compartment - NCRS Discussion Boards
  • Debra P.
    • September 30, 2004
    • 147
    Can anyone tell me if their should be some kind of rubber seal to line around the door ?
    Thanks in advance.
    Deb
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C 1 between seat compartment
    no. ya just adjust the latch catch so that it doen't rattle as you're motoring down the bumpy roads. mike
    • Dennis A.
      • April 30, 1999
      • 1010
      Debra...
      There is a very small rubber door stop mounted at the top. It does not do much for the door tightness however. No rubber seal is used around the door. Also two rubber bumpers are used for the deck lid.
      • Mike M.
        • May 31, 1974
        • 8385
        Dennis and deb: i forgot about the rubber bumper. sorry. mike
        • Christopher R.
          • March 31, 1975
          • 1599
          As another poster mentioned, adjust the door so it doesn't rattle. One of my Winter projects is to put some (removable) padding in there so that the contents don't rattle.
          • Dennis A.
            • April 30, 1999
            • 1010
            Chris...
            I carry a fire extinguisher wrapped in foam in my G-Box...takes care of any rattles. Also one in the trunk ready to do battle if needed.
            • Kevin Riel
              Debra,
              There is a "Glove box door stop" which is a little piece of rubber "c-channel" that is to be glued onto the glove box itself. The door closes against it. CC has them, as I'm sure others do too.
              Kevin Riel
