Phosphoric acid again - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Hello all! Last week I asked for help in finding phosphoric acid and got several very helpful suggestions. Most said auto paint suppliers would have it. Well, I called every auto paint supplier in the Detroit area and not only did they not carry it, many didn't know what it was. So I'm asking for any other help I could get (especially from Michigan Chapter members?). I really appreciate the help I have gotten from you all. Thanks.
    Jeff
  • Dick W.
    • 10483
    Re: Phosphoric acid again
    What you need to ask for is a metal etching wash. Metal Prep is one brand name (DuPont? PPG?) that I have used. Explain that you need to wash bare metal prior to priming. Hope this works
    Dick Whittington
    • Dick W.
      • 10483
      Hit the send button too quick. PPG # DX520
      Dick Whittington
      • steve wallach
        What about Home Depot?
        I get pool acid there, it works great, just don't spill it on anything.
        Steve
        • Jerry J.
          • November 1, 2000
          • 54
          Jeff; Approx. where are you. ?? I use "Dupont Metal Conditioner # 5717S".
          it's a concentrate mixed one part 5717S to two parts water. After diluting I use a spray bottle to apply.. Use rubber gloves and a -GOOD- mask..
          I get mine from Fergans auto parts on 9 mile in Eastpointe....
          • Chuck S.
            • April 1, 1992
            • 4668
            Jeff, I got a gallon at a local business that specialized in industrial chemicals and commercial janitorial cleaning supplies. It was straight concentrated phosphoric acid, and labeled as such...no rinses, no conditioning agents...they expected you to know how to use it. If you are live in urban Michigan, you should have no trouble finding such a business. Let your fingers do the walking...look under "C" for "Chemicals" or "Cleaning supplies".
            • Werner R.
              • March 3, 2008
              • 184
              anypalce that sells farm suppplies caries this as a material used to rinse milk tanks. in wisconsin i get all i want at "farm and fleet" for a few bucks per gallon. i use it to clean rusty bolts etc and it seems to work great. i store it in a small plastic sherbet container and just drop the parts in. they can be rinsed in a bicarbonate solution or just tap water, easily.
              • Gerard F.
                • June 30, 2004
                • 3806
                Jeff,
                Check out Jasco Metal Etch at your local hardware store. I'm not sure it is phosphoric acid, but it is used for etching and minor rust removal on small parts. I've used it from a spray bottle in combination with naval jelly.
                Also, muriatic acid cut 2 or 3 to 1 works pretty good as a pickling solution prior to replating. Don't leave the part in too long.
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                  • 43222
                  Jeff and Jerry-----
                  Jasco Metal Etch is mostly phosphoric acid. It's easy to obtain and works very well. I've used it for years.
                  • Gerard F.
                    • June 30, 2004
                    • 3806
                    Jasco Metal Etch
                    Jeff,
                    I looked it up; Jasco Metal Etch is a 40% solution of 75% Orthophosphoric acid plus some other nasty ingredients. You cut it 2 to 1 for heavy rust removal.
                    If you spray it, don't breathe the vapor, and keep it out of your eyes. You might want to have a bucket of baking soda solution available just in case.
                    I'm sure that this stuff is not the industrial strength stuff and it's fairly expensive. I paid $5.50 for a quart but they say it comes in gallon jugs.
                    Jerry Fuccillo
                    #42179
                    Jerry Fuccillo
                    • Jeffrey S.
                      • May 31, 1988
                      • 1882
                      Dick, Steve, Jerry, Chuck, Werner, Joe, Jerry, et al:
                      Thanks again for your help! I did get a recommendation for PPG Metal Prep from 1 paint supplier that I have trusted and have dealt with for years. The price for a gallon was $28 which, after reading your responses, seemed quite high. I also found a product called "Alumin-nu" which is for cleaning aluminum siding. Its main active ingredient is phosphoric acid and when I called the manufacturer I was told that it is excellent for removing rust from steel as well and is used industrially for cleaning steel siding. It was $14 a gallon at the hardware store which is reasonable. I will still follow up on all of your suggestions because I do still want pure phosphoric acid that I can dilute to my needs. Thanks again.
                      Jeff
