C1 Harmonic balancer - NCRS Discussion Boards
  • Kevin Riel
    When I disassembled the engine on my '59 there was not a spacer behind the harmonic balancer. Upon studying the CC catalogue I noticed that they listed a spacer that is supposed to be behind the harmonic balancer on a 58-62 283. My motor didn't have any pulley alignment problems that I am aware of, and I've rebuilt quite a few SBC motors and haven't had one with a spacer behind the balancer. Should there be a spacer behind the balancer on my '59 230 h.p. 283?
    Kevin Riel
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Harmonic balancer
    Spacer compensates for the thickness of the top motor mount, The mount spaces the water pump out about 1/8 inch and the spacer compensates on the lower pulley by spacing out the balancer/pulley assembly.
    Bill Clupper #618
    • Roy B.
      • February 1, 1975
      • 7044
      Most people don't realize it's missing because it's hard to see a 1/8 difference at a glance . But if you close one eye while looking at the pulley alignment you will see the difference . In most cases it won't hurt any thing not having it but could put wear on the belt or at most throw the belt off.
      • Kevin Riel
        Ok... makes sense. Thanks! *NM*
