Water Shut-Off Valves & Big Blocks - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4099
    With the exception of 1968s 427s, were any big blocks with C60 A/C equipped with a water shut-off valve? Tech manuals lead the reader to believe they were but AIMs suggest otherwise.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Water Shut-Off Valves & Big Blocks
    Sure, 67s certainly have them.
    • Mike M.
      • May 31, 1974
      • 8385
      even the small block c-60 equipped c-2's had a vac. operated shut-off valve to the heater.if one elects to turn on the a/c, the valve is supposed to close off hot water to heater core. howver, the switch that activets the shut-off valve is ofter times non-functional. long island sells a good repo. mike
      • Tom R.
        • June 30, 1993
        • 4099
        Certainly smallblocks but what about C3 big blocks *NM*
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Dick W.
          • 10483
          Re: Certainly smallblocks but what about C3 big bl
          Tom, I believe that the application of water shut off valves pertains to small and large block engines alike. At least from the cars that I have judged and had in my shop.
          Dick Whittington
            • 43221
            Tom------
            All 1963-71 Corvettes with C-60 had the water shut-off valve in the heater hoses circuit.
            For 1972-74, no Corvettes had the water shut-off valve.
            For 1975, only non-C-60 Corvettes had the water shut-off valve.
            For 1976-82, all Corvettes had the water shut-off valve again.
            • Tom R.
              • June 30, 1993
              • 4099
              Hey Joe:
              You've confirmed my conclusions with the exception of 69-71 big blocks. The AIM shows heater hoses for big blocks without the water shut-off valve but the P&A does not differentiate. So, big blocks were delivered with water shut-off valves?
              Apparently, the rationale for the use of water shut-off was inconsistent over this period (71-76). It appears as though engineers were testing the effectiveness of this device with 75 as a control (non A/C gets the valve) and afterwards they all get it!
              The 73-77 tech manuals are out of wack.
              Tom Russo
              78 Pace Car L82 M21
              00 MY/TR/Conv
                • 43221
                Tom------
                I just checked the 69-71 AIMs. The water valve is shown for C-60 with big blocks (sheet UPC C-60, D-6). It's not called out by part number as it is for the small block with C-60 but it's shown in the drawing. I don't know why it's not called out by part number. That would imply that the valve was part of the big block, non-C-60 installation but the valve was NOT part of the big block, non-C-60 installation.
