63 pcv system - NCRS Discussion Boards
63 pcv system
  • TerrLeahy
    63 pcv system
    I am in process of installing the original 327 in my 63-it had a68 327 in it with a pcv valve coming off the oil filler tube in the front of the intake.The original engine has a hole in the block behind the intake for aroad draft tube?Or should it have one of those round pyramid things bolted in there with fitting for the pcv?Thanks-Terry
  • William C.
    • May 31, 1975
    • 6037
    (Message Deleted by Poster)
    Bill Clupper #618
    • William C.
      • May 31, 1975
      • 6037
      Re: 63 pcv system
      The "Hat with nipple" arrangement can be substituted at the rear of the block functionally without difficulty.
      Bill Clupper #618
      • Joe R.
        • July 31, 1976
        • 4551
        Re: 63 pcv system
        The PVC system for the 300HP and the 340HP come from the back of the block with a metal and rubber plug. There was a pipe that connects to the plug and goes around the right hand side along the valve cover and terminates at the back of the carb. It is connected to the PVC valve via rubber hose. The PVC is screwed into a 90 degree fitting on the back of the AFB. If you are rebuilding the 327 make sure that the separator is installed in the valley of the block before installing the intake. No separator and that AFB will suck oil right out of that engine at high rpm. Oil vapor that is!
        Good luck,
        JR
          • 15677
          Re: 63 pcv system
          The best reference for the '63 PCV system is the '63 AIM. Pictures are worth a thousand words. Most of the required parts are probably available from the usual vintage Corvette parts sources.
          • Jim T.
            • March 1, 1993
            • 5351
            Re: 63 pcv system
            The 68 327 you removed is a lot different than my original owner 68 327/350HP. I have the oil filler tube, but there is no hose coming from it. Both of my valve covers have the PVC function. The passenger side is the fresh air supply connected by a hose to the air cleaner. The drivers side has the PVC valve with hose connected to the carb.
              Re: 63 pcv system
              63's had a one-year-only "reverse-flow" PCV system, where the "intake" side was a hose from the front of the air cleaner base to the oil fill tube, and the "exhaust" side was from the vent hole at the back of the block through an adapter and hose to the PCV valve on the back of the carb. Paragon and LICS will have the parts you need.
              • TerrLeahy
                Re: 63 pcv system
                I should have mentioned the 68 327 had an aftermarket alum intake with the 63 {no holes in them}valve covers.Thanks to all who responded.
