1963 Washer Reservoir - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Could some pleas decipher the following caricatures found on the bottom of a late 1963 windshield washer reservoir? Is there anyone that makes the correct replacement.
    Ther are: Number 2
    Two triangles with tow dots
    The letter A
    Thanks Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 1963 Washer Reservoir
    can't decipher the data but if i had to have an identical one, i'd hit the junkyards for late 63 GM pass cars. good luck, mike
    • Gordon Peterson #4961
      Hi Ray -
      When I was restoring my late '63 many years ago, the original reservoir was yellow, melted, and cracked. So it was destined to get replaced. But I still have it. I checked it for markings, and it has the identical markings to yours.
      The replacement for it was purchased in the mid-1970's. The markings on that one are two dots, C, 4.
      NO IDEA what all this means. Hopefully someone else can chime in.
      Pete
      • Joe R.
        • July 31, 1976
        • 4550
        Ray,
        Yes, I know what that means as I worked for a plastic manufacturing facility while in school.
        Those are the numbers for the casting machine, mold and position. If something is wrong the workers can check the code and get to the machine before it screws up any more pieces. The machine has four molds making four at one time. It just like the cast iron pieces on Corvettes. Ones such as the thermostat housing.
        JR
        • Ray C.
          • June 30, 2001
          • 1132
          Thanks! JR
          This site is great; the amount of knowledge is amazing.
          Ray # 36314
          Ray Carney
