Rubber splash shields - NCRS Discussion Boards
  • mac peppers
    does anyone have any tips for installing new splash shields at the A-Arms? i guess the factory had a large stapler of some sorts.
    thanks,
    mac
  • Mike M.
    • May 31, 1974
    • 8385
    Re: Rubber splash shields
    i reuse the factory induced staple holes when installing new rubber seals. clamp the seals to the inner skirt or have a friend hold them in place as you drill thru the fiberglass into and thru the rubber with a small drill bit. then install the new staples and bend each leg with needle nose pliers. time consuming but worth it. good luck, mike PS don't drill into friends finger.
    • mac peppers
      thanks mike
      • William C.
        • May 31, 1975
        • 6037
        I usually try to reuse the original staples, but if necessary, remember to use real steel, not Stainless for the staples.
        Bill Clupper #618
        • mac peppers
          i'm ready to give it a try, thanks *NM*
          • George C.
            • November 1, 2001
            • 568
            Re: i'm ready to give it a try, thanks
            Mac,
            Get the friend or wife to hold a piece of wood on the inside when you drill through from the wheel well side. A six or eight inch piece of 1X3 or 2X4 works great. This saves fingers and makes the job much easier.
            George
            # 36809
            • mac peppers
              good idea george, could save a marrage *NM*
