1972 Anti Theft Alarm Switch - NCRS Discussion Boards
  • Martin Z.
    Infrequent User
    • January 1, 1998
    • 26
    Looking for an original alarm switch for a 72. I believe it should have a "D" key pathway. Thanks
    Marty
    Re: 1972 Anti Theft Alarm Switch
    Alarm switch is a Paragon catalog listed item. You'll need to call/email and query them as to keyway specifics regarding their item (Is it a universal keyway switch? Will they sort inventory to get you a correct 'D' keyway unit?)
    • Bill E.
      • April 1, 2003
      • 200
      Marty:
      I bought an alarm switch a few years ago from Rik's Unlimited for my 1974 only to discover that it seems to be designed to mount in metal rather than fiberglass. It looks correct except that the grooves for the spring clip retainer are set too close to the face of the switch to allow for the thickness of the fiberglass. I have a replacement fender which is a little thicker than stock but the switch isn't even close to fitting. The switch can be modified to work but it still sits on the shelf in my garage as one of those "when I get around to it" projects.
      Have a great new year. Bill
