67 Interiors - NCRS Discussion Boards
67 Interiors
  • Al Tyson
    67 Interiors
    On the 67 there is a lever to move the seat forward. On a blue/white interior what is the correct color?
    Al
  • Bill W.
    • November 1, 1977
    • 402
    Re: 67 Interiors
    Mornin, Al,
    All 1967's used a chrome ball mounted on the end of the black accuation lever. '65 and '66 used a chrome lever. If yours isn't a ball type, someone may have changed it for you over the years. The correct one should not be hard to find. Bill
    • Carl R.
      • March 1, 1998
      • 166
      Re: 67 Interiors
      All 1967 cars use a small chrome metal ball on this protruding rod regardless of interior color configuration. Previous mid-year cars used a small flat lever.
      Carl
        • 43240
        Re: 67 Interiors
        Bill and Al----
        The ball may still be available from GM; it is GM #3846934. The last time I checked on it(can't check right now since I'm in the office)it was available. If I recollect correctly, though, it was quite expensive. Reproductions are available and, I believe, are less expensive.
