Trico Wipers- Are these ok for a '62? - NCRS Discussion Boards
  • Rob Edwards
    I purchased a pair of Trico wiper blades from a gentleman on Ebay and thought I'd share, mostly to see what the consensus is on whether these are right or not. The part that mounts on the wiper arm has a riveted spring arm, and has PAT 2,752,626 on one side and 2807822 on the other. The arms themselves have black plastic hemispherical end caps, the Trico logo near each end and a bunch of patent numbers. The 12" rubber blades have 48 dots, 3 full and 2 half elliptical bumps, and 3 zones of embossed printing: "Trico" in the middle, "Patent 2543383 PAT PEND CAN 1949" in the right mid, and 2 lines of text near the right- "BR. 593775.702900" on top, and "PAT.2733469 CAN.54 BR 733626" below.
    Any thoughts or comments? Thanks!
  • William C.
    • May 31, 1975
    • 6037
    Re: Trico Wipers- Picture won't download *NM*
    Bill Clupper #618
    • Rob Edwards
      Oops, thanks Bill, picture attempt #2:
      • Roy B.
        • February 1, 1975
        • 7044
        Re: Trico Wipers- Are these ok for a '62?
        They look OK to me , the rubber inserts can have the Elliptical bumps or not , remember there was more then one supplier to Trico. I have wiper blades with both bumps and none. My 2cents
          • May 31, 1974
          • 8396
          could we see a photo of the fitting that the wiper arm slides and clips into? thanks, mike
          • Dave S.
            • August 31, 1992
            • 2926
            The configuration of the holders, tips and rubber inserts look correct to me. It has been my understanding that the patent numbers on the SS holders are not correct for original pieces. They should only say TRICO. Can anyone out there shed some light on that.
            • Rob Edwards
              Mike- Here you go-
              I've got a shot of the top of the fitting as well, if you like.
                • May 31, 1974
                • 8396
                Re: Mike- Here you go-
                rob: it's the top surface i look at to determine originality. mike
                • Rob Edwards
                  A shot of the top
                  Hope this angle shows you what you want to see!
                    • May 31, 1974
                    • 8396
                    Re: A shot of the top
                    that's the view i needed, rob. i don't believe the originals had the rivet yours demonstrates.mike
