C2 Oil Filler Tube - NCRS Discussion Boards
C2 Oil Filler Tube
  • Rich Freeman
    C2 Oil Filler Tube
    I'm changing the old oil filler tube on my 66 327/350 and the old one is stubborn. Are there any tricks to getting the old one out and the new in?
    Rich
    Re: C2 Oil Filler Tube
    Rich -
    Put a piece of broomstick in it and work it around in a circle to loosen it up, then just pull it out. To install, orient it so the PCV bung is in the right position, put a 2x4 block over the end of it, and whack it with a large hammer - it's a press fit.
    • Bob R.
      • June 30, 2002
      • 1595
      I sprayed PB Blaster around the base and let it sit for a couple of days. The tube loosened up and was easy to remove by hand after.
      • Floyd #21606
        Re: C2 Oil Filler Tube - John
        John,
        I used your broomstick method to remove the oil filler tube on my L-84.
        It work like a champ. Thanks for the information on it's removal.
        Floyd,
        65 Fuelie
        • Rich Freeman
          Thanks everyone!! The broomstick method worked.
