C3 console radio covers? - NCRS Discussion Boards
  • dick foehringer
    i was restoring trim stuff today and had a question. on one side of the radio side trim there is an extension and the other side not. there are 4 screw posts on each pannel. ive looked thru the books and dont see anything else that is supposed to be attached to them. so what are the screw posts for? i also found my passenger kick panel looked like someone took a hacksaw to it, but looked in the assembly manual and thats what it said was for the assembly line to cut as per diagram...interesting.
    thaks, dick
  • Jack H.
    • April 1, 1990
    • 9906
    Re: C3 console radio covers?
    When the car was equipped with factory A/C, they, indeed, took a 'hacksaw' to the kick panels to gain clearance on convertibles for the extra, underdash reinforcing braces, used. Same goes for the LH side radio panel--Shark convertibles incorporated a panel extention that screwed to the backside of the stock panel to hide/mask the under-dash reinforcing brace that attached to the transmission tunnel....
