67 clutch pedal - NCRS Discussion Boards
67 clutch pedal
  • Rex T.
    • December 1, 1984
    • 455
    67 clutch pedal
    I am in the process of changing my 67 powerglide Corvette over to a 4 speed. I know that the clutch pedal assembly is unique to 1967. Does anyone know if the brake pedal is also unique, or will the brake pedal from any mid-year 4 speed Corvette work? Also, are there any other parts that are unique to 1967 required for this type of swap? Thanks and happy holidays to all. Rex #8089
  • Mike M.
    • May 31, 1974
    • 8396
    Re: 67 clutch pedal
    if you're not concerned with originality, any midyear clutch/brake pedal assembly will fit in your vet. mike
    • Rex T.
      • December 1, 1984
      • 455
      Re: 67 clutch pedal
      Thanks for the response Mike. I was told that ONLY a 67 clutch pedal will work due to the collapsible steering column. If I use any midyear clutch and brake pedal, will I have to change anything else, or will they bolt right in?
      Rex
      • Mike M.
        • May 31, 1974
        • 8396
        Re: 67 clutch pedal
        Rex: you are correct about the collapsable col being different and hence needing a 67 pedal assembly to fit. however, i think the 63 to 66 pedal frame will fit up in your 67. it'll be trial and error. good luck, mike
          Re: 67 clutch pedal
          The pedal support assembly is unique to '67 due to the mounting holes and surfaces for the intermediate steering column support bracket; you can't use a pre-'67 pedal support with the '67 steering column. Keep the pedal support assembly you have and get the correct '67 pedals.
          • Rex T.
            • December 1, 1984
            • 455
            Re: 67 clutch pedal
            Thanks John. Volunteer Vette offers a repro 67 clutch pedal, but no brake pedal. Do you have any idea if anyone makes a repro brake pedal, or will a 63-66 brake pedal bolt in? If not, I will have to try to locate an original brake pedal assembly. Thanks again for your input and happy holidays. Rex #8089
              • 43238
              Re: 67 clutch pedal
              Rex-----
              The brake pedal for 1967 was unique to that year. I don't think that any reproductions are available for this part.
              • Rex T.
                • December 1, 1984
                • 455
                Re: 67 clutch pedal
                Thanks Joe, and as always, I appreciate your help, as well as everyone who responded. Happy holidays to everyone. Rex
