gravity bleed - NCRS Discussion Boards
gravity bleed
  • lyndon Sharpton
    gravity bleed
    what are the pros an cons to using the gravity bleed system? also could you do it with out jacking the car up are taking off the wheels. has anyone done this?
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: gravity bleed
    Lyndon,
    The only con is that it is slow. On some cars you can do it without removing the wheels but it is usually easier to just remove one wheel at a time if you don't want to get the whole car off the ground.
    Wayne
      • 15696
      Re: gravity bleed
      Also consider that for every minute the m/c or a valve is open glycol fluid is absorbing moisture.
      I try to do brake flushes during very low humidity weather, which out in in So Cal typically occurs in the fall.
      • lyndon Sharpton
        Re: gravity bleed
        I can see doing the front brakes, but I dont know how you could do the back with out taking off the wheels?
          Re: gravity bleed
          You can't - the rear wheels have to come off. A home pressure bleeder takes 99% of the grief out of bleeding Corvette disc brakes.
          Home Pressure Bleeder
          • Scott Marzahl
            Re: gravity bleed
            John,
            Is this the type that pressurizes the system from the master cylinder rather than creates a vacumn from each of the calipers? I have the vacumn type which seems to work OK, this however seems like it would be much faster.
              Re: gravity bleed
              Yup, pressurizes the master cylinder and you don't have to keep checking the fluid level in the master as you move from bleeder to bleeder - it keeps it full as you work.
