69 alternator differrences - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Does anyone know what the differences are in regards to appearance between alternators 1100833 and 1100881 and especialy the late 69 to 70 1100900? All I know is that they are all 42A and appear to be close from what ever pictures I can find. The reason I'm curious is that I would like know if the 1100900 would look correct on my early 69 even though it appeared several months after my car was built. Thanks.
    • 43245
    Re: 69 alternator differrences
    Greg------
    The 1100833 and the 1100881 are externally identical except for "numbers".
    The 1100900 has the same drive-end case configuration as the the above. In other words, it has the "large" front case openings which extend all the way to the perimeter of the case.
    I believe that the split-ring (rear) case half is the 1970 style, though. This is identical to the 1969 except for 2 features: (1) there is a small raised rectangle below the Delco-Remy script, and (2) the ground bolt mounting lug is on a boss which is raised off of the rear of the case by about 1/4". The 1969 case used a mounting lug which was nearly flush with the rear of the case.
    Both the 1969 and 1970 split ring case halves use the "7 fin" heat sink.
    • Greg L.
      • March 1, 2006
      • 2291
      Thanks Joe, that the info I was hoping to get.
