C3 Wide rear Tires - NCRS Discussion Boards
C3 Wide rear Tires
  • Dennis A.
    • April 30, 1999
    • 1010
    C3 Wide rear Tires
    What are the widest rims/tires that can be mounted on the rear od a '69 without off-set T-arms or adapters? also; I seen 15x10 advised, were they an option for C3's and will they fit with modifications? T.U.
  • Warren F.
    • December 1, 1987
    • 1516
    Re: C3 Wide rear Tires
    I can attest to the fact that a 265x50x15 BF Goodrich Radial T/A tire will fit just fine, mounted on a stock rally wheel.
      • 43221
      Warren-----
      265-50-15 is a very difficult size to find anymore. I wasn't even aware that B. F. Goodrich still made a tire in this size. The only one that I know of is a Dunlop.
      • Craig Skaaden
        Dennis-
        I have LR50-15 [1970 vintage] Goodrich Radial T/A tires on 15x8 wheels on the rear of a 68 and they just clear. I would think that 15x10 wheels will require some type of modification, probably to the emergency brake cable attachment to the trailing arm where the tire could rub.
        • Dennis A.
          • April 30, 1999
          • 1010
          Thanks a bunch, guy's *NM*
          • Kenny Hancock
            Re: Thanks a bunch, guy's
            This is slightly off the subject, but what experiences has anyone had with offset trailing arms?
            • Dennis A.
              • April 30, 1999
              • 1010
              Off set T-arms
              Ken...
              Good Question...Also any suggestions on how to install? or is this a "take it to a Professional"?
