C2 Radio Side Panel Screws - NCRS Discussion Boards
  • R N.
    • May 31, 2002
    • 640
    Hi All:
    I've seen two different types of screws to attach the radio side panels in place. The ones I think are correct are a phillips head chrome screw with a built-in washer, a one-piece unit.
    The other one I've seen is a also a phillips chrome screw, but with a separate cone-type washer that is attached just under the head of the screw.
    Which screw is correct?
    Which of the vendors have the correct screws?
    As always, thank you for your help.
    Kurt
  • Joe R.
    • July 31, 1976
    • 4550
    Re: C2 Radio Side Panel Screws
    Kurt,
    The Philips head screw with the washer made on. Sorta flares out to make a very large screw. Long Island sells the correct screw along with many other vendors. The other screw you have seen with the washer is just a common upholstry screw.
    JR
    • R N.
      • May 31, 2002
      • 640
      Thanks, JR *NM*
