C1 Engine ID Help - NCRS Discussion Boards
C1 Engine ID Help
  • George D. 31849
    C1 Engine ID Help
    Can anyone help me ID the following numbers on a 61.
    Block = 3769935
    Front Pad = F0227D or O
    Intake = 9872788
    LH Cylinder head = 3795898
    RH Cylinder head = 3795896
    • 43221
    Re: C1 Engine ID Help
    George-----
    The block casting number is 3789935 and not 3769935. Based on the production code and casting number, the block was originally part of a 170 hp 283 installed in a late 1961 passenger car. The cylinder heads are GM #3795896 and are "power pack" heads which were originally used on 1962-64 283 and 327 applications.
    The intake manifold is GM #3872783. It is a Holley (square) flange manifold originally used on some 1966 and 1967 327 engines, including 300 hp Corvette.
