1965 BRAKES - NCRS Discussion Boards
1965 BRAKES
  • Duane Sorensen
    1965 BRAKES
    I have sleeved calipers and non power master cyclinder. Can not get pressure with out pumping brakes. Have gravity and vacumn bled the brakes. Any suggestions. Help. System worked before sleeving except for leaks. Have bled other brakes and this car before without this problem. Im on my 7th try. All parts are original to the car except the sleeving.
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1965 BRAKES
    Might be time to get a kit to rebuild the master cylinder.
    • Mike M.
      • May 31, 1974
      • 8388
      Re: 1965 BRAKES
      agree with jim. ya might also want to replace the rubber hoses if not done already. mike
      • Mike McKown
        Re: 1965 BRAKES
        When you get done doing what these two gentlemen suggested, try using a pressure bleeder on your brake system. I have used "pump the pedal", "gravity bleed" and "vacuum bleed". But, the only consistently successful process I have used is the "Pressure bleed" on the Corvette four piston calipers. The other three methods work fine on either drum or single piston caliper brakes. They just don't seem to work well on the Corvette.
        • Terry F.
          • September 30, 1992
          • 2061
          Re: 1965 BRAKES
          To some extent, you might have some improvement in results if you raise the end you are bleeding up in the air as high as you can get it. It worked for me. Good luck, Terry
