69 blower motor plenum color? (non ac) - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    Near as I can tell, the fiberglass blower motor housing in the engine compartment on my 69 was in place during the blackout procedure...is this correct or should it be bare fiberglass? Thanks
  • Robert C.
    • December 1, 1993
    • 1153
    Re: 69 blower motor plenum color? (non ac)
    The right front inner rear fender area got a LITTLE blackout. Most motors I have seen have little or no black-out, maybe a little overspray.
      The engine compartment blackout operation was performed in the Paint Shop, and the heater assembly wasn't installed until later on the Trim Line; I'd expect any black material found on the heater housing or blower was overspray of black vinyl plastisol sealer material that was occasionally applied to seal the top of the blower housing to the firewall for water leak prevention or repair.
      • Greg L.
        • March 1, 2006
        • 2291
        Thanks guys. Bare fiberglass it will be. It made more sence to me, from a production stand point, that the blackout was completed before any components were installed, but it sort of appeared that there was no blackout on the firewall after I removed this housing so I wasn't quite sure, but know I know for sure. Thanks again.
        • Terry F.
          • September 30, 1992
          • 2061
          Do you know of anyone that makes a similar or the same black plastisol sealer for around the heater box and other places that it is found. Terry
