C2, L76 Coolant Flow Rate - NCRS Discussion Boards
  • Les Jacobs
    What is the approximate flow rate of coolant thru the water pump at idle? (Im guessing around 4 gal/minute.) Thanks in advance. Les
    Re: C2, L76 Coolant Flow Rate
    Dunno about idle, but it's 57 gallons per hour at 4400 rpm.
      • 15673
      A flow rate is listed in the AMA specs. All are the same - about 4 gal/min at 2000 IIRC.
      • Stephen L.
        • May 31, 1984
        • 3158
        57 gal/hr sounds low... thats less than a gal/min
          Oops! Meant 57 gallons per MINUTE, not per hour
          • Les Jacobs
            Thanks *NM*
              • 15673
              Correction
              The oil flow rate is 4.3 GPM @ 2000.
              Coolant flow rate is listed as 55 GPM @ 4400. It's not clear if this is crankshaft or engine RPM. The water pump/crankshaft speed ratio is 0.94:1.
              • Les Jacobs
                Re: Correction
                So if the flow rate is 55GPM @ 4400 RPM, then at an idle of 750RPM it would be approximately (750/4400)X 55 = 9+ GPM. Is this correct?
                  • 15673
                  Re: Correction
                  I'm not sure! A positive displacement pump like the oil pump will have flow delivery approximately linear with speed in the normal operating range, but I'm not sure if centrifugal pumps' delivery is linear.
                  Any centrifugal pump experts out there? This is one engineering question I can't answer off the top of my head.
