63-67 testing wiper motors - NCRS Discussion Boards
  • Richard L.
    • December 1, 1994
    • 43
    Can anyone tell me how to bench test a 63-67 Corvette wiper motor? I would like to test it before installing. There are three connections, which gets power and which are grounded? Do I need the switch to test it? Thanks Dick
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 63-67 testing wiper motors
    Observe the color code on the wiring diagram and determine which color does what, or goes to what power source. Then look at the plug that is connected to the wiper motor for the color of wire going to which contact. Make some notes and then connect your power sources to the appropriate motor terminals using clip leads.
    Good luck
      You'll find pretty good detail regarding bench testing a WSW wiper motor in your copy of the '63 Corvette shop manual....
      • Louis T.
        • July 31, 2003
        • 282
        Several of the members were very helpful when I had a similar question about my 1965. Check out the string of links below beginning 11/4/04. Good luck.
        1965 Wiper Washer Woes
