Shade of grey for rear spring? - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    I am curious as to what shade of grey the rear spring originally was. I had read in earlier posts that the paint is available from Quanta, but also seen many posts mentioning other more readily available paints. So is it a light grey like the typical grey primer? Or is it like battleship grey, or charcoal grey, or what? My spring is a repro and it came in black. Thanks!
    • 43221
    Re: Shade of grey for rear spring?
    Tim------
    The color of the Ionoklad coating is a light gray, similar to gray primer. It might even be a little lighter than gray primer.
    • Gary B.
      • February 1, 1997
      • 7024
      Tim,
      Also be careful about texture and sheen if you are not going to use the Quanta rear spring paint. It's more than just color that's important.
      Gary
      • Tom M.
        • August 31, 2000
        • 231
        Often refered to as Dove grey.
        Tom McCabe
          • 11643
          Yep.
          It doesn't cost that much to buy the correct liners and paint in the kit from Quanta. You might as well buy the correct items and do it right. You will NOT want to re-do it after the judges tell you it's not typical of factory production.
          Patrick
          • Wayne M.
            • March 1, 1980
            • 6414
            Can email (up to) 10 pics of original '65 spring .
            ... which I disassembled and exposed to daylight for the first time. The grey remains only on the (approx) 1 foot center section, and you can see the color variations where diff. lube has had effect. Also shots of top of springs, showing oozing from spring above when factory assembled. Also side-by-side shots of grey spring and (darker) grey original shocks, to appreciate shade differences.
            These jpegs are about 800Kb each, and can provide blow-up detail.
