340HP with Air? - NCRS Discussion Boards
340HP with Air?
  • Michael G.
    • January 1, 1997
    • 1251
    340HP with Air?
    Good day Corvetters,
    My local newspaper has a 1963 Corvette advertised with the 340HP engine option. The seller indicates the car has A/C. Could a 340HP be ordered with air? Thanks in advance.
    Mike #28614
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: 340HP with Air?
    Nope, But someone could of added it or build the lower horse engine to 340hp specs. (or at least made it look like one)
    Fast rap Hi rev solid lifer engines would have likely thrown the belts off PS and AC so GM didn't offer the options on these are from the factory.
    tc
    • Wayne M.
      • March 1, 1980
      • 6414
      C2 (factory) Solids w/air only in '64/'65 *NM*
      • Mike M.
        • May 31, 1974
        • 8389
        Re: C2 (factory) Solids w/air only in '64/'65
        both wayne and tracy are correct. GM solved the high rev. A/C compressor belt throwing problem in 64 by using a larger pulley on the solid lifter A/C compressors and hence offered c-60 on the 365 hp vettes as well as the hyd lifter 64's( which came with a smaller A/C pulley than their 365 bro's.). mike
          • 15680
          No C60 option on '63 L-76, but as stated, it was available on L-76 beginning in '64. The alternator was moved to the LH side in order to mount the compressor on the right.
          No C60 with L-84 because the air cleaner didn't leave enough room for the alternator on the LH side.
          Notwithstanding the above, there's always a way to install an aftermarket AC system, but they are rarely as well engineered as OE systems.
          • Mike M.
            • May 31, 1974
            • 8389
            dukle: back before NCRS, i put a rochester unoit on my 64 365 c-60 coupe.what a plumber's nightmare. still have the ole coupe. back to original and its still one of my favorites.used to drive it from morgantown wva to parkersburg wva on the weekends in early 70's(was moonlighting a ER to support lea and the kids and my vette habit) the ole 64 had a 306 rear in it and would run real well down us 50 to parkersburg. came upon a pack of wild dogs one nite, about 6 or 8 of the coon dog types(best i could tell they were coon dogs at @ 80 mph) when i hit about half of them. can still remember the floorboards bending up and displacing my shoes as i over-ran them.didn't hurt the front valence--they musta been miget coons. regards and merry christmas. mike
            • Tracy C.
              • July 31, 2003
              • 2739
              Great story Mike, remember to share this one with
              the grandkids as you gather round the Christmas tree this year.
              I just see it now....
              Tell us a Corvette story PoPo Mike..
              Well I came upon a pack of wild dogs one nite, about 6 or 8 of the coon dog types(best i could tell they were coon dogs at @ 80 mph) when i hit about half of them. can still remember the floorboards bending up and displacing my shoes as i over-ran them. didn't hurt the front valence--they musta been miget coons....
              Lea will be so pleased with you...again!
              Merry Christmas you ole coon dog killer..
              tc
