anti-sieze - NCRS Discussion Boards
anti-sieze
  • Mark H.
    • July 31, 1998
    • 384
    anti-sieze
    what is the best way to remove permatex anti-sieze? I need to remove it from a fitting so I can use thread sealant instead. Thanks.
    • 15677
    Re: anti-sieze
    If you're referring to Permatex Form-a-Gasket (the brown goo in a tube), it should be soluble in denatured alcohol.
    • Ralph E.
      • February 1, 2002
      • 905
      Re: anti-sieze
      Mark,
      If you really mean anti-sieze spray on stuff, I would try try using lacquer thinner.
      Ralph #37280
      • Mark H.
        • July 31, 1998
        • 384
        Re: anti-sieze
        Not the spray on stuff, but the stuff in the tube. Comes in two varieties that I've seen - one is a silver color and the other is copper. I've found that the stuff gets everywhere and is very hard to clean. I'll try the lacquer thinner.
