69 9 Leaf Rear Spring - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    I purchased a 9 leaf rear spring thru e-bay that was from a 1976 and it appears to be in excellent condition. However, I want to use it on my 69 for NCRS judging, but cannot compare it to an original 1969 because mine was replaced with a repro unit. I have several questions regarding this spring.
    Will a 9 leaf spring from a 1976 be correct for a 69?
    How many liners should there be on a 9 leaf spring?
    Are there liners between all leaves?
    What are the lenght of each liner?
    I purchase a rebuild kit from Corvette Central and there are only 7 liners.
    Thanks for your help.
    George
  • Gary B.
    • February 1, 1997
    • 7028
    Re: 69 9 Leaf Rear Spring
    George,
    Have you read my article from a couple of years ago in the Corvette Restorer? If not, I recommed it. It documents the standard rear leaf springs used from 1963 thru 1977. For 1976 the standard spring was a single-stage, 10-leaf spring with 9 liners. For 69 the standard spring was a two-stage, 9-leaf spring with 7 liners. So, if you really did buy a 76 spring, any careful judge should be able to see that it's wrong for your 69.
    Gary
