67 door panel trim repair - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    I have two broken tabs on the upper stainless trim on a door panel. I believe these trim peices are called race tracks. Does anybody know of a way to attach the trim to the door panel in the location of the missing tabs?
  • Ed Jennings
    Re: 67 door panel trim repair
    Make a new tab out of sheet metal with a "T" at the end. Bend the T slightly so it will fit into the trim and then straighten to lock in.
    • Randy R.
      • March 1, 1983
      • 477
      I made a "T" but could not get it to slide between the stainless outer metal and the plain steel backing.
      • Ed Jennings
        On some pieces, depending on how they are made, I've had to cut a small notch on the midl steel piece to give the T tabs a slot to go in. Used a dremel tool. May want to give it a try. The alternative is buying a new one and they are sort of pricey.
